Help! Car Keeps Overheating!
It all started when I got a leak in my water pump. So I changed the water pump, put new coolant and water in, drained the air out of the radiator, put a new thermostat in and now... my car is still overheating. I don't understand what the problem is. I changed the water pump, everything looks good. What else could it be causing it to overheat? It does okay for a few minutes while running, but then the temp guage shows it getting hotter and hotter and the check guages sensor comes on. What is the problem? What can I do?
my car is doing the exact same thing and threw code p0161, my water pump was even leaking. what water pump did you put in?
my fans wont turn on either, no matter ho hot it gets
i cant figure it out???
REad this, it may help. if you didn't remove all of the air from the block, the cooling system isn't going to work correctly.
http://shbox.com/1/4th_gen_tech2.html#radflush
1996LT1Z28
Middle Atlantic
12-04-2014 09:37 PM
1996LT1Z28
12-04-2014 09:20 PM
