help with coil and igniton?
ok i got a 95 z. i am putting on a msd blaster coil part#8226, msd 6a ignition and msd wiring harness part#8876. ok i am running it to some trouble. my first question is when i took my stock coil off there was a bracket mounted to the coil that had a wire connection to it. the directions say nothing about removing it from the stock coil but if i leave it off there will be an open connection on my car. second question on my msd coil there is two conections and the harness that i got plugs into the factory wire right but the part that plugs into the coil it leaves half of the plug open and that what the diagram shows but is tht right to leave a comection open on the coil, but when i look at the diagram in the msd ignition booklet it shows to splice the wire and then the two conections are pluged but i don't have that plug or don't i need it. i called jegs and msd and they were not sure.
Originally posted by qwick_trip
ok so i need to take that peice off right? then mount it to the msd coil! ok now what about the conector on the coil one sides stays open?
Originally posted by mkent
i'm just reading in and trying to learn here...is this good for any kind of performance gains?
Neither of these things is something you might feel, but sometimes the MSD does add a little smoothness as some have experienced. I think it depends on the state of your existing plugs and wires as to what you might feel after install. A slight increase in gas mileage is a possible benefit.
