Help determing cost of Modified LT1 heads and Cam
Hey guys ...
I'm considering upgrading my Head/Cam package soon to larger heads and a much more aggressive cam ...
My current head and cam package produced approx. 405 rwhp & 428 rwtq on a 383 LT1 ... and only have a little over 4,000 miles on them
The heads will be assembled and inclued the roller rockers as well ...
Here are the details:
Camshaft
Make/Type: Crower/Hydraulic
Grind Number: Custom
Intake Exhaust
Gross Valve Lift (1.5:1) .555 .565
Duration @ .050 231 239
Lobe Separation 112
Intake Centerline 108
Valvetrain
Rocker Arms: Comp Cams Pro-Magnum 1.52:1 on 7/16 studs
Rocker Studs: Comp Cams
Valve Springs: Comp Cams 985
Retainer: steel
Heads Professionally Ported
Make: GM LT1 (ported)
Intake Port Volume: 190 cc
Valve Make/Material: Ferrea stainless
Valve size: 1.96 intake 1.56 exhaust
Valve notes: intake valves fully backcut
Chamber volume: 55 cc
What would the appropriate asking price for these and would anyone be interested ...
Thanks, TIM
Camshaft
Intake Exhaust
Lobe Separation 112
Valvetrain
Retainer: steel
Thanks, TIM
Not sure ... the cam is a torque monster and the torque comes on quick, over 400 rwtq at 2800 rpms ... very, very streetable ...
I would think what most Head/cam 350s make in the horsepower range but a little better in the torque range
I'll send you $5 + shipping right now
It all depends though, if you have some flow #s it will probably help with the sale of them and also a casting # from the heads.
Good luck with the sale and sorry I couldn't help more
oldschool
02-09-2016 09:21 PM
