Help with disc brake install
Hey,
I have a '95 Z28 with disc brakes, I was wondering if anyone had any tips or tricks they use for putting the pads and rotors on. I've had trouble with a squeal even through replacement with Delco Performace slotted/drilled rotors and preformance pads. The car makes this noise like they're catching on something every once in a while you hear this squeak, quiet, squeak kinda noise, but it goes away with brake pedal application.... I've also discovered a driveline squeal in the tranny with no brakes on the car and turning the drive shaft in neutral and I am not sure if thats the real culprit.... Does any one use a disc brake quiet product?
If anyone has some ideas or thoughts, I would love to hear them, thanks
Cool ZR
Cool ZR
hotrodyou1
12-20-2014 10:05 PM
