HELP!! Dyno Run: This cant be normal!
I got 1 run on the dyno today and the results were 237.2 Max power and 267.7 Max torque! Is this normal with CAI, Jet Hot LT's, no cat, flowmaster, and TB Bypass? I mean isnt a stock z28 like 280 hp? Im really down right now, i was hoping for at least 290-300 hp. Also i got a Air/Fuel gauge and im running lean and rich at the same time, is this normal? The gauge goes crazy when i step on the gas and when i let go of the gas it falls down all the way. I think there is something seriously wrong with my car what do you think?
Dyno Sheet
Dyno Sheet
Originally posted by ledfootz28
arent lt1 rated at 275 at the flywheel and more like 240 sumthin at the wheels?
I'll get the dyno sheet online tonight, How can i find out my fuel presure and timing?
Both numbers are down 20 from stock.
LT1's dyno about 255/290
Look at it this way, at least you found out that there is a problem so that you can fix it and max out the potential of your Z28.
Dan
Dan
Dan
Dan
