HELP! eXHAUST IS SPITTING OUT WATER AND ANTIFREEZE
#16
Headgaskets, dont drive it. Pull those heads ASAP to avoid rust, otherwise it builds up pretty nastily, and that is not going to be good for the rings even if you get most of it off somehow. If you overheated and this caused the leak, you can assume you will need to get the heads level-checked and/or may end up having to toss 'em, or use them as practice port heads for fun.
#17
Thanks,the car was never driven after this happened,so at least i didnt put anymore strain on the motor.I hoping all it is ,is head gaskets.I think we ran the car for a 1/2 hour ,but like I said we never drove it .It stayed in neutral at idle,so hopefully I lucked out.
carguyshu
01-22-2017 11:19 AM
warmeck
03-01-2015 08:47 PM
