Help a friend troubleshoot his 383
Hey guys
One of my buddies has a 1995 Z28 that weighs about 3800lbs with a 383 in it and its a 6spd
and 3.42 gears
He got it dynoed and is wondering why it is lacking some (alot of) performance.
Dyno Graph
The stock casting heads supposedly flow:
.100 64.2 47.8
.200 132.8 92.3
.300 188.6 134.5
.400 237.7 160.0
.500 267.1 179.1
.550 277.8 186.9
.600 279 191.7
Cam is a 230/236/112 .544/.555 lift with 1.6 rockers
Stock intake manifold/stock tb/stock injectors (DC were only at 83% max on a WOT street run
up to about 6300rpm)
Compression is a static 10.7 or so, but its cut down b/c his elevation
We thought it would have made at least 400rwhp and about the same amount of torque. He
suspects the heads, what else could be losing 85hp?? And why does it take a dump at 5000
rpm?
He has trapped 104 mph at a 10.5k DA, but we're not sure what that converts to at SAE
conditions.
Thanks guys
edit: Oh, by the way, he has a base tune from pcmforless
and 3.42 gears
Dyno Graph
.100 64.2 47.8
.200 132.8 92.3
.300 188.6 134.5
.400 237.7 160.0
.500 267.1 179.1
.550 277.8 186.9
.600 279 191.7
rpm?
conditions.
Thanks guys
Some of the stand out items to look at are:
Stock TB
Springs(maybe stock?)
Injectors, regardless of Duty Cylce, these should be stepped up.
I would assume since you had the heads flowed, you changed the valves, springs and so on. From the higher compression we would also assume you had the heads decked.
You also didn't mention anything about exhaust or cats?
If the springs are good (that is not stock), I would suggest a larger TB and bigger injectors if the exhaust can keep up.
Some not so obvious things to look at are lifters (stock?)
Pushrods touching the heads. This occurs a lot when switching to higher ratio rockers since the contact point moves closer to the fulcrum.
How high is the elevation?
Stock TB
I had the same problem when I built my engine, but I switched to a larger T/B and the cam your freind is using and the car woke up. Can he confirm cylender pressure?
Definately have the intake portmatched to the heads and the throttle body larger. The fuel may be running out as well.
Since his fuel injectors are not maxed out could there be some tuning issues?
Sounds similar to what happened to my car, the power peaked at 4800, instead of 5800. After that the car just seemed to bog down. I talked to madwolf about it, and he sent me a new tune, and it really woke the car up. It felt like at least 50 hp extra, probably more than that, but I dont have any dyno runs. Try having someone look at your tune, even if thats not the problem im sure ull get a few extra hp out of it
It's all in the correct combination. IMO, the TB and intake are not hurting that to the degree that you think. The tuning may need to be addressed, but you need data logs to properly diagnose tuning issues. The heads/cam combo may be suspect in this case as well as the tuning.
http://m0nk.sytes.net/images/wot383.uni
the link works locally, tell me if anyone has problems, it should work thou
