help here---Is my tranny?
The car jumps really bad when going 1st to 2nd gear, but shifting manually don't. I re-programmed PCM with new wheels & tires size but still jumps.. is this the tranny ???
need help
need help
Ok.. It´s not a hit from a firmer shift.. What I meant is that when the car shift from 1st to 2nd.. start bouncing on the rear.. so I have to let the Gas pedal and then step on it again to stop the bouncing..
thanks..
thanks..
If the back wheels are hopping check what S.J.S. said. Are the shocks original in the back, that could be contributing to the problem. If your tranny mount is broke, that will make the car feel like it is jumping up when the transmission slams into the bottom of the car.
