help with hooking up manual fan switch
i am ready to hook up a manual fan switch. the only question i have is: i have two led's with resistors in them. when you go from the +12V source to the led, do you use the positive or negative section on the led? in the diagram it says the anode so i thought you just simply went from the +12V source to the negative wire on the led. however, the guy i talked to at radio shack said it only made sense to go to the positive wire on the led. i still say its the negative but i just wanted to make sure.
clownhair, i have led's with resistors in them and the led's have a red and a black wire. so for me it is easy to tell which is positive and which is negative. i guess i was right. the +12V source goes to the anode. the guy at radio shack told me the opposite.
well, now we have another problem. i have it all hooked up and the fans work fine on high and low but the led's flicker but don't stay on. i am not sure what i need to look for. i have only one wire for ground with two others tapped in to that one. i assume thats alright?? i am also using the same +12V source for the high and low fans. i assume that is ok also?? besides all that, i checked the connections and they look good. unless my ground needs to go somewhere else. any help would be great.
so i guess what i am confused about is: right now i have led's with built in resistors and i have the +12V going to the negative part of the led(anode) and i have the positive part of the led going to the dark blue wire for the high speed and the dark green for the low speed. so what your saying, since everything works fine but the leds just flicker and then go off, i need to possibly check the +12v source?
sorry for confusing you shoebox. i thought i was taught that the anode was negative and the cathode was positive. i guess i have them backwards then. i will try that and see what happens. thanks for the help everyone.
also, the switch works. when i turn it on low the fans come on low and when i turn it on high the fans come on high. just the leds flicker when i turn the switch on high or low but don't stay on. i will switch some wires around and see what happens.
