help an impala guy out...
opti (and harness),O2's,PCV,wires, plugs, egr (and solinoid), checked vacuum(21*), cleaned tinys,throttle body, and IAC. TPS is within spec. car still has irradic idle when in gear (stopped). it also likes to unlock the converter on the highway every so often for no apparent reason.
tonight i had the A/C on and the car idled perfectly while waiting at lights, any ideas? lazy IAT? maybe just bumping the idle up a hair would help? i have autotap but im not too familiar with it, anything in particular i should look for?
this is starting to **** me off
mods-2800 edge, gears, bryan herter programming, other than the idle condition it runs like a raped ape, but i want it to idle like it should
EDIT- also changed the coil,and the IC module
Re: help an impala guy out...
Describe "erratic"...... does it shake with minor irregularities/misfires, or is the idle rpm surging and varying more than the normal +/- 25rpm? Or maybe a combination of both?
If you have an AutoTap data log, I'll be glad to take a look at it for you. You just need to send it in .csv format so I can open it with Excel. If you are looking at the data log, look for irregularities in the MAP sensor readings at idle.
Do you still have the original coil and IC Module in the car? How many miles on it? Ever cleaned or changed the injectors?
Just curious.... what is the "tinys" that you cleaned?
i also replaced the intake gaskets along with the other things mentioned without any change in the condition...
any idea why it idles perfect with the A/C on, and not with it off? i will work on getting you a log, i have some stuff to do today, and i need to figure out how to get it to .csv format...i appreciate your help
Originally Posted by Dave89IROC
A/C puts a load on the engine and forces the PCM to up the Idle/IAC position
my car does the same thing ,but not all the time , it seems like using the a/c triggers it more often but it does happen when its off too. About twice a week this happens , then its gone.
Was the BH tune before or after the Edge? If it was before, an update to the tuning is in order. The lighter looser converter can confuse the pcm and it will suge looking for some load on the engine. My cammed Caprice with programming even did this till I had Bryan send me an update for the TC, I had thought the cam and bumped idle for it would have taken care of the problem that was the only reason I had not had Bryan send me a new tune before I drove it.
I am about 95% sure I have the answer for you guys. I had the same problem. Took me 3 weeks to figure it out. BTW, it's FREE!!! Check this out...
Click here
Click here
i replaced the IC module, no change
Originally Posted by arrowcamaro
when im stopped at a light, i have taken to throwing it into neutral, it's more steady(the idle) than sitting there in drive.
Originally Posted by BLinindoll
Yep, exactly what I had to do. I'm tellin ya, try the mod. It worked for me.
i also took out the airfoil, removed ECU and checked connections-all looked good. i need to get my autotap working... and get that log file to someone who knows what there looking at.
