Help, installed heads backward
#16
Originally posted by Dr.Mudge
I'm not going to recommend doing it, but Fel Pro headgaskets have been reused multiple times, successfully. I dont blame you for not feeling right about it, nobody wants to do the job twice.
I prefer to put the coolant tube on before putting the heads in the car, it is a huge PITA for me with the oil sendor in back. I cut the tube in the middle and use a rubber hose now as my cross over. Huge convenience help for me, I never undo the cross over anymore, just toss the heads in and voila.
Stock Fel Pro gaskets at my local auto store cost about the same as OEM, about $22 each.
Thanks!
Rich Krause
#17
Will, I think you've started a trend here :^)
I'll add a "me too" to the separating of the coolant return lines.
Great idea Will, Thanks for sharing man,
-Christian
www.carprogrammer.com
-Christian
#18
took the heads off
I ended up taking my heads off , and I will put them back on today. This is a big PITA, but next time I will know. I will reuse gaskets and bolts, and I hope it will hold good. Thanks for help,
Tomas
Tomas
10-31-2016 11:09 AM
F(ast)-body
02-26-2003 09:05 AM
