help... LT header installation
Okay guys here is the problem, we were doing a header install in my buddies 94z28, Btw these are Pacesetter Long Tubes. Well We finally have them installed but, what can we use to cap off the A.I.R holes in the headers?
Re: help... LT header installation
If you put the AIR injection stuff on the header you can remove the check valve and use a 1/2" pipe cap. Or you can use a M22 drain plug bolt. I found one in a small auto parts store near the HELP section.
