HELP!!! My 93 lt1 won't start.
Ok people this is the deal, after a few bolt on mods to my 93 lt1 Camaro it cranks but it won't start. Mods are: ported Throttle body to 52mm, BBK shorty headers, cc305 camshaft, 1.6 roller rockers, accel coil w/8.8 spark plugs wires, NGK TR55 spark plugs, EGR removed w/ A.I.R. tubes removed and custom chip burn by PCMFORLESS by Alvin for all this stuff done. Also a optima red battery. When I was finish putting it all together it started and ran a little rough I shut it off to check on a few things, now it won't start . Now any help would be greatly appreciated . As mention before the car will crank over but it won't start . sometimes it sounds like its about to start but it doesn't. I check for spark and fuel and both are ok so what can it be ? Please help anybody. Thanks in advance.
Re: HELP!!! My 93 lt1 won't start.
Double check that you have the wires on the correct spark plugs. Also might try cranking with the fuel pedal to the floor (flood mode) in case it's getting too much fuel.
10-31-2016 11:09 AM
