Help Needed
Help Needed
okay so i ran into a new one today and just seeing if anyone had any ideas i got my car out for the first time in probably two months and was gonna take it to the car wash for a quick clean up before taking the women on a date i pulled in the car wash and realized i was low on fuel so i decided to go the gas station first as i started to leave the car layed down and died. so i just thought i would go get some gas and continue on. i put ten gallons in it and the car still wont fire i am not sure it was completly out of gas as the gauge still read about an eighth of a tank but i know the car is a little on the dated side now i checked and fuel pump still running and no fuses blown and i even changed the coolant temp sensor but mostly just because it was bad anyways. thanks for any feedback in advance
Re: Help Needed
Have you checked the fuel pressure? Have you scanned it for codes?
When my fuel gauge is on 1/4, there is about 1 to 1.5 gallons left. It's been that way since I bought it new in 1994. It's such a universal problem with these cars, Shoebox has a good online article on the gauge's quirks.
4th Gen LT1 F-body Tech Articles
I never let it get that low.
Re: Help Needed
and i never meant to let it get that low but last time it was out it was at the track and kept fuel low but normally i put a half a tank of the expensive track fuel lol but i guess i made a few more passes than i though or something it was lower than normal
Re: Help Needed
As far as I know, there is no worse car to completey run out of fuel then the LT1. You should go buy a fuel pressure gauge and for about $25 you can use it over and over again. Get one with the long hose so you can use it hooked up while driving, if need be.
10-31-2016 11:09 AM
