HELP! Oil pressure drops to zero when braking hard!!!
Ok guys, I noticed this happening for the first time today on the way to work. I hit the brakes hard, and suddenly saw my "Check Guages" light on. This is the first time I've ever noticed this. On the way home, I tried it again. Sure enough, under hard braking, the oil pressure will drop to zero, everytime. I did just change the oil today, but it got it's usual 5 quarts. Should I maybe try to overfill it? The dip stick shows that it is full. I do have the stock oil pan, but have rebuilt the motor, and I went with a brand new Melling High Volume oil pump. Is is possible that so much oil stays in the block b/c of the HV pump, that not enough stays in the pan, and when I brake it sloches away from the pick up tube? I'm lost. I cannot continue to have this problem though. Any suggestions are welcomed. Thanks!
I don't mind raising it a bit...but I don't want to pull it again. The motor has been out of the car more than it has been in it.
I'd like to add that the car holds 50-60 PSI oil pressure at idle, and almost 80 PSI while driving.
Before I go to the trouble of dropping the oil pan, I can't help but think that maybe there is a connection to me changing my oil today. I know I put in 5 1/2 quarts, and I know I didn't double-gasket the filter. I also ran the car last night at the track, and I wonder if there is a connection there also. Any suggestions?
I appreciate the advise Shoebox. I did an interesting experiment a little earlier. I first got the car to speed, then slammed the brake and held the clutch, and of course the oil pressure fell to zero again. The next several times, I got the car to speed, threw it in neutral, and held the engine at 3000 RPM and 80 PSI oil pressure, while I slammed the brake and brought the car to a halt. The oil pressure never dropped past the 40 PSI mark in all of my attempts. If this were a problem with the pick-up tube coming uncovered, shouldn't the pressure fall of quicker if it is holding constant at 80 PSI when the car comes to a halt? I know the car did not have this problem this morning before I changed the oil. I'm going to change the filter tomorrow, and see if by some wierd freak accident it is related to the filter. Who knows.
Just in case you have to pull the pan I just did mine after dropping in new 385 and had 2 rods hitting the pan. You don't have to pull motor, just jack it up 3 inches, In my case I also lowered the K-Member a 1/2" and then the pan came out. Good Luck
I had the same problem with my 97 Camaro. I went under the car and pounded on the oil pan with my fist and heard a clank every time. I ordered a happy hooker from TPIS, lifted the motor high enough to pull the oil pan and fixed the oil pump pickup. Good Luck!!
Courtney
Courtney
