Help pulling a lt1 from the top?
Re: Help pulling a lt1 from the top?
You will definitly need to unbolt the trans. There just is not enough room to get both out without getting into some radical engine angles using a engine hoist
-Shannon
-Shannon
must unbolt tranny before it somes out from the top. i just did a v6 to a lt1 swap, pulled the v6 from the top. installed the k-member then installed the engine from the top with the hood still on by myself. i didnt have a problem with it. but i left the intake and the valve covers off to help. the radiator was also out.
You don't have to unbolt the transmission. Quite a few people take them out connected from the top. I am taking mine out right now , but when I do , I unbolt the engine, but when I put it back this time , I may connect them . I have seen pictures ,and talked to people on this forum that do it that way. I think the main thing when taking them out together is to have the car jacked up high enough. I think someone said the minimum is about 15 - 17 inches for it to work that way. I did some measuring last time and that seems like it's about right. Although if you could get the car closer to 2 feet or higher , it would be easier.
To the original poster , I don't know if one way is "better", but it is probably "easier" take the engine out by itself. When I tooke mine out the last time, after we hooked the chain up to the block, the engine was seriously probably out of the car within five minutes. Just turn the engine side ways in the engine bay 90 degrees , with the front and back of the engine facing the shock towers. When you turn it like that , nothing is sticking up under the winshield (which is the case with 4th gen cars when the engine is facing forward). So then you can just lift it up like a "normal car", and pull the engine hoist back.
i say both are about the same dificulty easier in some respects more dificult in others but as for the tranny issue as long as you pop the shifter off first and thenjack the rear end up as high as it can go it will give you the angles and the clearance you need to pull it from the top
Ive done both within the last 2 weeks. Bottom is 10x easyer imo. Its also a bonus because you can put it in from the bottom fully assembled.(headers ect...) Bottom took me 5 hours with several warmup breaks, and it was my first time. Took me longer to take out the damn radiator then the 6 cradle bolts.
Originally Posted by niteninja
I pulled mine from the top, but next time I will take the hood off. I unbolted the tranny from it, but they will go back in as one.
Yeah. I took the hood off also. Some say they have left it , but I will take it off again.
You can pull both at once,but you need a "Happy Hooker" Or you can leave the tranny in the car on a jack. Either way it's pretty simple with a lifting device like the hooker.
Take off all front end acce's and the balancer,radiator(leave air condenser),take air compressor off and let it stay in the frame don't have to break any lines,PS same way.Turn front of engine to the drivers side and come on out. You may have to take the bolts out of the ABS block so it won't rub and thats it.
The only thing I did different was to turn the front of the engine to the passenger sid. LOL.
Gtpguy
01-26-2015 04:50 PM
formula218
12-02-2014 04:27 PM
Darth Xed
13
07-22-2002 12:45 PM
