Help Question About Wheels For Lt1
DOES ANYBODY KNOW IF THEY MAKE SPINNING WHEELS FOR A 94 CAMARO. I FOUND SOME 18X9 SIZE WOULD THAT FIT THE FRONT AND BACK. WHATS THE OFFSET HAVE TO BE 38??? - PLEASE LET ME KNOW ANYBODY
Mike, that all depends on your offset. But my 18x9 wheel with +50mm offset with 255/40-18 installed stay fully within the fender...checked that because I plan to lower it later.
With a +38mm offset, your tire will actually sit out farther (closer to the fender), so not sure. Check with your wheel vendor.
If you've lowered your car, all bets are off and you should check with your wheel vendor.
ChrisFrez
11-30-2014 08:41 AM
07-04-2005 05:00 PM
redzed
09-04-2002 06:22 PM
