HELP!! Remove broken pipe tap from oil galley opening
so i was trying to tap the front 3 oil galley holes w/ a 1/4" -18 pipe tap and it worked great on two openings and then the third one it broke.
Here are some pics. What is the best way to get it out? I tried to use a screwdriver and a hammer to try to budge it since I feel it will turn out if it busts loose but then I broke the end of the flathead screwdriver in there as well as you can see in the bottom left of the pic.
What are the best methods?
Should I have something welded to the end of it like a bolt and then turn that out? or are their tap extractors that would work. keep in mind it is stuck in there pretty good and I did put a bunch of wd40 on there to try to loosen it up.
Any help is appreciated. I was planning on having the crank and the pistons in tonight but that isn't happening.
thanks
thanks
thanks man, appreciate the help and ideas. Going to get the tap replaced tomorrow and then see what I can do.
http://www.waltontools.com/products/extractr.htm there are things called broken tap extractors that may help you out if the broken end isnt too too wedged up into the casting material too badly. this is only one link for them. i have a set but the picture is a pain to post. just google broken tap extractor. you will find many of them.
Hardened tool steel- probably as hard as any drill you have- the welding idea could work, if you have a talented welder- the heat would serve to loosen it, too-
We used to burn them out with a device in the shop that looked like a drill press with an arc welder electrode instead of a drill bit-
Stop what you're doing and take it to the machine shop - it needs to be milled out with carbide end mills. You cannot touch a tap with drill bits or HSS end mills. The only other option is to try and break it into little pieces, it should be very brittle...which is why it's able to be so sharp.
FYI, in the future - those front oil galley's have a mis-matched step which will break a tap every-time, you need to use a face ground tap so that you don't go in as far.
This country needs more jobs like that, but we need to get back to manufacturing stuff, first-
i would do my best to remove that pesky screwdriver tip first. drill it and use a small punch to defeat the rest of the tip. then you can fit all 4 extractor tips into the broken tap and remove it. just take your time and be careful.
I was able to retap those 3 front oil galley holes no problem. Going to finish cleaning the block on wednesday, clean my heads, and then fri/sat/sun will be putting the motor together.
again, I appreciate the help, thanks.
centric
08-15-2002 09:04 PM
