Help Removing Starter
Re: Help Removing Starter
I finally got it out but i could not bring it out the front had to bring it out between the exhaust and the transmission lines it was a bitch cant wait to put it back in.
carefully bend your tranny lines a little bit and it will fit thru that hole without a problem if you have it twisted the right way. make damn sure you have the little red wire on the correct small post or the first time you start the car, the starter will stay spinning even if you take the key out. have a friend ready with a 8mm ready to dissconnect the battery the first time you start it.
Oncomingstorm22
01-22-2015 07:15 PM
