Help w/ engine swap.....
Maybe someone can tell me where I screwed up. I just finished putting the new motor in my 94 TA. I got no spark. Everything I can see is plugged in. Everything else worked when I pulled the motor. Is it possible to install the opti or the drive wrong??? Been here since lunchtime finishing up to get here.
how did you pull the motor?
and go here http://shbox.com/1/4th_gen_tech1.html , there is a walk through to check for opti signals IIRC
yeah, here it is http://shbox.com/1/4th_gen_tech2.html#opti_test
I unplugged everything from the components and left the harness in the car. If I didn't line up the opti right, like if I accidently got it on 6 instead, would I have the same problem? My brother and I both looked over the whole car and couldn't find anything that was unplugged.
JasonD
08-23-2010 03:14 PM
Caps94ZODG
22
07-30-2002 08:45 AM
