Help w/ installing NON-vented optispark
So since I took the old style optispark off and didn't have a clue where it was positioned do I now have to make sure the #1 cylinder is at TDC and then install the new opti?
Note: I have the new vented one but I don't have the time to swap the cam out to accept the new style optispark.
Thanx, Rob
Thanx, Rob
no the shaft will only go into the opti in one position look at it, it has a spot that is larger on the teeth just keep turning the opti until it mates to the shaft and fits onto the mounting bolts like its supposed to
Dan_the_ManZ28
02-21-2015 02:01 PM
07-04-2005 05:00 PM
