HELP Where does the factory tach get its power/reading from?
Originally posted by TexasTechTA
the signal for the tach in the opti is it high or low resolution? I thnought the tach ran off the coil.
thanks I just want to know which one it is shoebox says the tach runs off the opti and pcm and you say it is the coil It hought it was the coil but shoebox said no does anybody know 100 percent?
I think i? figured out wehy the car is hard to start and the tach went out when i did the comp test on my car I did not pull the ign fuse so the spark from the coil shorted the wire on the coil that goes to the tach which connects to the otpi. so the high res is ogne on the opti. does that seem possibler I do not have an olmeter to check but I am taking it in tomm shoebox what do you think?
Originally posted by Fastbird93
The tach gets it's signal from the coil, and through a filter that's taped to the wiring harness right next to the coil, then straight to the tach.
The coil also gets it's firing signals from the pcm (see B5 [ignition control] at the bottom of this diagram.
There are no wires from the coil to the tach that I can see.
Then again, a 1993 might be different.
Originally posted by shoebox
Looky here and find A13 (tach output). It goes from the pcm to the tach.
Bigfatrat
Parts Wanted
10-16-2015 04:48 PM
