Here are the specs.. help w/rpm range
Hey guys... here is a cam I had given to me... to use... I'll be using it w/ported heads... What I'm trying to figure out is wether or not its gonna turn too many rpms to make its power for me to use spray as well... in other words.. will it make power above 6500 or so... b/c I'd like to not have to turn that high w/spray on stock bottom end....
268/277 548/564 108cl solid roller
Thanks guys
Thanks guys
Damn man, if your running a stock bottom end with that big cam it would have to rev pretty high to make power. the cc306 and gm847 are a little smaller and have to be revved over 6500rpm, then on spray it should put a little more stress on the bottom end. i believe there are better alternatives cam wise like the 224/236 114LSA. just for comparison the cc306 is 230/244 and the gm847 is 234/242 112LSa also, you might want to try maybe a custom grind or a smaller shelf cam on a 114LSA.
Or re-ring/re-bearing the bottom end along with some forged pistons and that should give you more peace of mind.
Hmmm guess I'll have to wait and go with a hydraulic roller .. something smaller... the cam is free so thats why I was wondering... But I don't think 6800 shifts and 125 shot are gonna do well on the stock bottom end
NewsBot
09-14-2015 02:02 AM
08-07-2015 08:52 AM
