Hesitation and Backfire
Hey guys I have 97' T/A and my motor hesitates when I step on the gas, and stumbles. Also backfires when full throttle at high rpm's. Check plug wires all good, plugs are 6 months old, have new delteq and fuel pump. I have 96,000 miles on my car, what do you think I should look for?
Clogged fuel injectors?
bad fuel pressure regulator?
vacuum leak?
vacuum leak?
Re: Hesitation and Backfire
Changed to delteq about 8 months ago, changed all plugs and wires then. Just checked plug wires last night, all good, check them for resistance of course not just an visual check. Fuel pump is about 4 months old. Haven't worked on the car in last few months.
Need more details.
Could be ICM and/or Optical sensor in Opti spark.
Or a huge list of other things.
check out this thread we are all working on a similar problem.
http://web.camaross.com/forums/showthread.php?t=371298
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
