High RPM vibration after M6 Swap
I just got done installing a M6 in my formerly A4 Z28. It drive pretty good except for when you rev it up above 4k RPM's it has a really noticeable vibration. It does it when it's in neutral but does it far worse when you are getting on it and rev it up high. It didn't do this with the A4 in it.
I bought a new clutch, pressure plate, TO bearing and a Pilot bushing. I also had the flywheel resurfaced.
I didn't have the flywheel balanced or anything.It is a stock flywheel of a 96 LT1 same car i got everything else from. Should i have had it re balanced to match the flex plate off my A4 setup.
Also when i let the clutch out in neutral it has a lot of bearing noises. What would this be. Also give me some other ideas of stuff that could be causing. The clutch is a brandnew SLP set up.
Shawn
Shawn
