High volume oil pump at what clearances?
Old 07-18-2008, 01:50 PM
  #16
marshall93z's Avatar
Originally Posted by rskrause
Some engine builders like bigger clearances for very hi-po motors. The idea is that there is more deflection and that a thicker oil film will minimize metal to metal contact under these circumstances. That's they way my machine shop does it and it makes sense to me. I can't say if it's true or not though.
Rich
And for not perfectly machined parts... like my Eagle crank!
marshall93z is offline
Old 07-20-2008, 08:59 PM
  #17
The_Bishop's Avatar
I guess that makes sense, that's what we used to to in the machine shop I learned/worked in. But we usually reserved that for pretty potent motors; stockish stuff got stock clearances. Hell, I built a 357 c.i. chevy motor that made about 615 HP in a drag car that ran 9.70-9.80 and that was at stock clearances with 10w30 synthetic oil so I didn't have as much oil pump loss / spark scatter. That engine lived through over 100 passes before I sold it and as far as I know the guy who bought it is still running it. Only thing it needed changed regularly was valve springs about once a season. Before I sold it I swapped out the bearings, and they still looked pretty damn good.
As far as the eagle crank situation - I would've either sent it back or if that wasn't possible, sent it to a crank grinder to get straightened out.
Rich
The_Bishop is offline
Old 07-21-2008, 05:29 PM
  #18
I guess I meant cheap stuff, in general. Runout, tapered journals... stuff like that.
Old 07-21-2008, 10:24 PM
  #19
mitchntx's Avatar
Not just Melling ... get Melling Select pumps. The housing and internals are more robust.
mitchntx is offline
HectorM52
07-30-2017 11:46 AM
HectorM52
06-23-2016 08:42 PM
DirtyDaveW
03-15-2015 07:01 PM
carl.froehlich
03-13-2015 12:38 AM
Hoodshaker
08-27-2002 02:32 PM
Quick Reply: High volume oil pump at what clearances?
