Highest lift cam with short valve covers.
#18
#20
Due to my turbo manifolds I have to run short valve covers. My heads flow 317cfm at .700 lift and heads are setup with .650 lift springs. I'd like to run the highest lift I can possibly run with short valve covers. One cam I'm looking at is .630 lift with 1.5 rocker arms. The other is .619 lift with 1.6 rocker arm. I'm thinking if I run a larger cam an shorter ratio rocker arm I can get away with more lift. Is that right?
#21
