Highway driving with a 396 Stroker
I'm debating whether to tow or drive a 94Z 396 stroker with TH400 and 4.10 rear from Detroit to Stanton, MI for a race on Saturday (~160 miles one way). Since the TH400 doesn't have an overdrive, what's a reasonable rpm limit for cruising long distances, 3k? 3.5k? less? or am I insane for even thinking about driving it there?
With 4.10's and a "street" tire (25.7" diameter) you are going to be turning 3,760rpm at 70mph. Even more with a non-locking converter. I run the TH400, 4.10's and a Gear Vendor, and I tow to the track, which is 6 miles from my house.
On the other hand, many years ago, the typical street car was running those kind of RPM's on the street, because none of the trannies had O/D back then, and everybody who raced ran 4.11's or 4.56's. I don't remember anyone towing their car to the track in the 60's.
I say tow, because Stanton always has awesome traction, especially at all the "M" events, so the chances of breakage are always there, especially with a high horsepower application and a stock rear end. (I'm assuming you've got those 4.10s in a stock 10 bolt?)
I can remember newly-introduced solid roller rocker-equipped small blocks reving beyond 10k back in the late 70's.
On the positive side, I was amazed at the performance improvements of fuel injection over carbs, in terms of fuel efficiency, drivability and power output.
Originally posted by tnthub
With the stock rear I would tow it. I drive just about anywhere with mine but a transbrake and a 10 bolt just doesn't make sense.
