holy burnt spark plug wire!
#16
Re: holy burnt spark plug wire!
Thanks alot guys...
matt 65- The boot on the taylor wires is pretty fat...so that really isn't a bad idea!
Green-Thanks for the link...i believe i've read a little bit about those before. So is that exact set (the link you posted), the set that will work on the LT1?
#17
Originally Posted by 1QuikTransAm
Thanks alot guys...
#19
I checked the plug wires this evening and the only boot that was burned was #5, and thats because the heat sleeve slipped off.. I thought #6 was against the header primary also but its not...just real close. I'm going to repair my #5 spark plug boot with a boot that i retrieved from one of my old taylor wires. Hopefully this will last, at least for a little while.
If not, i'll proabably be going with the accel shorty plugs and the 9000 wires.
Thanks for all the input everyone!
#23
just use the shorty plugs on the cylinders that need them. Shouldn't be more than 1 or 2 cyclinders that need em.
I heard Accel also makes these plugs. Anyone have some part numbers?
#24
Well i did a little research and it looks like i'll be swapping to the accel shorty platinum's...only $12.73 a PIECE. Geez...
auto supply house and buy two Autolite 104's for about $1.20 each....
they are the same length as the Accell shorty.
You may like the ease of plug changes with these plugs so much
that you may replace ALL of your plugs with them. I run the
104's in all cylinders.
Emil:93Z,383
Darth_tsunami
V6 Tech
09-18-2015 01:57 AM
