Home made 3" duals over the axle done!!!! *PICS*
#61
So I'd say a fair price would be in that same neighborhood I'd venture to say..nothing less than $500 for sure.
Since my last post above I did completely redo mine myself with 3" and 2.5" mandrel bent over the axle and it kicks *** compared to what that bone head muffler shop did the first time around.
#64
I was just wondering if any of you have had any issues with the pipes rubbing under aceleration or hard turns or any of that type stuff? I am afraid I would get every thing finished and it would rub the floorpan somewhere.
#65
Make sure your motor mounts aren't worn or get a poly mount on the driver side, that will keep the motor from torquing over any. Mine have a hanger on the tail snout of the tranny and connects right around the X-pipe and then a hanger on each muff at the rear bumper and are rock solid, the pipes hardly move at all.
#67
I havent had any problems withrubbing. I have poly motor mounts and a poly trans mount. The only issue I had was the I had to reweld a hangar twice. I think thats just because the two hangars in the back are supporting all the weight.
I used a cheap chop saw to make all the cuts. If you dont have one its worth buying. I beleive its either a 14" or 15" saw.
#68
wow, you guys all got ripped. It cost me $200 to build my true duals with spiral flows
got the mufflers used for $40 shipped
x-pipe setup was like 100
clamps
hangers
welded it up myself
and now, i have to ditch em anyways
clamps
hangers
welded it up myself
#69
Just a chop cutting wheel saw like mentioned above. They come in very handy for tons of other things, can get a cheap one at Harbor Freight for about $35 if you don't need an industrial strength one. The one I got was on sale for $29 there, it lasted long enough to build my entire steel garage and do my true dual exhaust then it crapped out..but had a 3 year warranty so I took it back and got another for nothing
#70
Are your duals out the back of the car, over the axle? There is more than $200 in materials to do so. Or do they dump before the axle?
#71
01-23-2015 01:13 PM
