Hooker Catback and Headers
Hey everyone,
I'm thinking of going with the hooker catback and long tube headers. Couple questions.
1. What is the life like on the hooker catback since it is alumnized and not stainless.
2. With the hooker headers, am I going to have clearance issues because of I have Kenny Brown Diamond Double SFCs?
3. Do hooker headers normally come with a Y-Pipe, or is that something I'll need?
4. For the hooker catback, will I need to take it to an exhaust shop to put in, or can I do it myself? I dont have a means of welding.
Thanks!
Thanks!
Re: Hooker Catback and Headers
Originally posted by bobbykokinos
Hey everyone,
I'm thinking of going with the hooker catback and headers. Couple questions.
Thanks!
Hey everyone,
Thanks!
The subframe connectors will not interfere at all. Hooker or Jet-hot long tubes do not come with a Y-pipe. I'd recommend either having a shop custom fabricate one, or buy the Hooker Y-pipe, which you can get for $169 from www.ls1speed.com or you can get it from Jet-Hot for about $25-30 more and it is ceramic coated, and the other is not. The hooker cat-back you can install yourself, it does not require welding, Should take about an hour or two to install.....the hardest part is getting the old cat-back off. Good luck!
Matt
Re: Re: Hooker Catback and Headers
Originally posted by Cmr0z28
Hey. I'll assume you're talking about Hooker long tube headers. If so, I'll start out by recommending that you buy Jet-Hot long tube headers. They're the same thing, but cheaper, ceramic coated, and have the o2 bungs already welded in, which the Hookers don't. The Hooker cat-back should last a good 10 years assuming that you don't drive the car every winter through the salty roads.
Matt
Matt
Also I was looking at Jet-Hot headers.. Now does Jet Hot coat hooker headers and sell them, or do they sell there own that just happen to be alot like hooker?
Re: Re: Re: Hooker Catback and Headers
Yeah, sorry, I meant the long tubes..
Ok, another stupid question.
If I got the JetHot headers, hooker Y-Pipe, and hooker catback, will it all be pretty much "plug and play" or will I have to do any kind of fabrication or cutting?
Hmmm ok.. I think thats the setup Im going to go with. JetHot, Hooker Catback, and Hooker Y-Pipe.
I guess I'll also need to O2 sensor and might as well do over the valve wires and plugs while Im at it. Probably should get locking header bolts also.
Anything else anyone can think of?? I'm looking at spending around $1000 from start to finish, right?
oh, and 24" o2 extensions
www.ls1speed.com has them cheap but i believe jet-hot sells them cheaper.
Right now I'm doing 13.9 in the quarter.. How much different would it be??
