Hooker long tube screws and installation
What screws have you used????
I am having problems with the passanger side and the inner screws. The screws get stuck with the inner flanges of the passanger side...
What do I need??? more patience???
LMK
LMK
Where do I get those???
The problem here is not that they get loose.. is that I cant tighten them... My bolts are touching the exhaust tube and I cant get a small wrench in there and I I tried to use allen bolts and I cant get an allen tool in there either... space is too tight!!! too tight!!! too tight!!!!!!!!!
LMK what you guys use and pics if possible...
I had the same trouble with my ARP 12 points. If it wasnt for my buddy Jason Short and his wrench I wouldnt have been able to get them off. Its a wrench with a real, real thin edge to it. If you got a 6 point bolt it should be too much of a problem to get a wrench in there...
I have a 12 face 10mm screw... it doesnt work that well either, the wrenches just dont fit well... I will try and get the screw shaved a bit to see if it helps... I was trying to use allen screws and it doesnt work that well either...
I dont know what to do... I am beginning to hate theese headers...
Its been 2 days to just install them.. I hope I see big gains over my shorties...
This has been a real PITA.
Any other suggestions???
01-05-2015 07:14 PM
