Hooker Longtube guys
ok trying to get these new headers put on so i can finally start the new stroker setup but.... having trouble installing the passanger side header. Do you have to jack the moter up on that side to get it in or what. (wish i would have put it in when i had the tranny out a few days ago now.)
Re: Hooker Longtube guys
What got it in for me was jacking the car up VERY high. Dangerously high, then it slipped right in. I had to put my jack on cinderblocks with plywood on top. Make sure to invest in the good jackstands for safety reasons
I had to remove the valve cover, alternator, dipstick, and the heater hose that runs along side the engine. Do this plus lift the engine up (just the passenger side) and they will drop right in.
I didn't have to touch the motor mounts on mine. That was before I got the 2 post lift and had to get it way up off the ground to get them in from the bottom.
I guess the next post will be "I can't get the motor mounts to line up"
