How to adjust throttle and TV cables?
After I put my 93 together (94 swap), I noticed the throttle cable does not work right. With the gas pedal all the way down, the throttle looks about 60-70% open. The throttle body is the same one that was on the original engine. How did this happen?
Also, how do I adjust the stupid TV cable. The way I read it on the board here is have someone push the gas pedal all the way, then press on the TV cable's button and pull it towards the firewall, then depress the button.
I tried to do that, but something obviously isn't right. First of all, with the throttle open, I can't pull the cable more than 1/3 of an inch. (just enough to take it out of the bracket) Even with the button pushed.
I did it like that but the car shifts completely like crap. Any ideas?
Thanks!
Thanks!
ok here's what i do:
push in the button and pull the cable all the way back towards the fire wall. then ( on a stock cable it should have a cone on the inside of the lock) push it to the bottom of the cone and start from there until you find where you like it for part throttel shifts
did you reuse the 93 intake? i think the 92-93 intakes are a **** hair longer then the 94 + but i am not for sure on this aspect though
please feel free to ask if there is any confusion and i elaborate ferther
Eric
Eric
Re: How to adjust throttle and TV cables?
Eric
Eric
thanks for all your help with this.
I am not reusing the 93 intake... the only 93 thing on the engine is the TB with the TPS and IAT valve... oh, and the TV/CC/Throttle cable bracket.
I don't think I'm understanding this correctly. Do I push the button and pull the cable with its end connected to the TB? That's what I have been doing. Without it connected, it doesn't make sense.
And like I already mentioned, it just won't pull any further than 1/3 of an inch past the bracket.....
Thanks again guys.
Ion
Re: Re: How to adjust throttle and TV cables?
Originally posted by Got-LT1
I can help with that one... I'll send you an email by the end of the week with the pics of how I and several others fixed that damn problem. All I needed was two washers and a nut.
Do you also have a 94+ engine or is this a common issue?
Re: Re: Re: How to adjust throttle and TV cables?
Thanks!
Thanks!
EDIT: Wait, does your throttle body have 3 cables running into it? If not then I wouldn't know how to fix it.
Re: Re: Re: Re: How to adjust throttle and TV cables?
Every 1993 I have ever seen has this problem.
yup it has to be attached and its not more than a inch of total movenent with the throttel closed
all the ajustments i make are with the throttel closed then a test drive to determin if i got it right
also i have never had a prob with my throttel opening all the way the only time was when the floor mat was in the way.....oops
sorry for the tardyness in my reply
Eric
Eric
Thanks again, Eric. I got it all figured out. Shifts very nice now.
I was pushing the button and pulling on the whole thing, instead of just the cable. Now all I gotta do is fix the 60% max throttle thing...
ya, its great to have control over your part throttle shifts, by mearly a tug on a cable but its a PIA to get it right the first time.
well glad i could help out i some way about that intake maybe you could just throw a couple of washers between the throttle cable bracket and the intake until you get it right
good luck and i should be able to let you know how the programing works soon (I hope)
Eric
Eric
carguyshu
01-22-2017 11:19 AM
jimmybandana
05-11-2015 11:41 AM
