how big is too big?
how big is too big?
im in need of a new fuel pump (i think) anyways after the car sits for a few hours you have to cycle the key for it to start...and the fuel pump runs o.k i guess, but it will just crank and crank then finally start.
is the 255 to much for the mods i have...i plan on going with the 224/230 in the future and some long tubes to go with it, and some svo 30lbs injector.
thanks for you info.
steve
steve
Originally posted by whitedakota
bleed back valve???
is that the same as the fuel pressure regulator?
steve.
bleed back valve???
steve.
http://web.camaross.com/forums/showt...hreadid=169541
read that, in that thread there is a link from "Shoebox" that will help ya trouble shoot if not fix it
09-18-2015 03:46 PM
NewsBot
08-03-2015 02:40 PM
