How can I determine if my MAF is bad or not...
By unplugging it and letting it go into speed density mode and seeing if it idles better, dont have a scanner or a spare good one.
Eric
Eric
Why do you suspect your MAF is faulty? Have you ever cleaned it? (electrical contact cleaner) If you don't clean it, road grime/dirt will impede the sensors correct operation and make it react slowly. If I didn't have a scanner, I would try a unit off a buddy's car to see if my car ran any better.
drove it around with it...
disconnected, having a issue with a detonation as it shifts into 2nd gear and a load is put on it, I tried it connected and disconnected and it pinging either way. So I rule it out, I cleaned it several times with electrical contact cleaner.
Eric
Eric
carguyshu
01-22-2017 11:19 AM
[Exterior] BMW & Mercedes can look like 5th gen Camaro
Husbarn
03-30-2015 11:45 AM
formula218
12-02-2014 04:27 PM
