How can I tell the difference between 7/16 and 3/8 studs
I honestly feel stupid for asking this, but I have a set of GM 1.6 rockers and I need poly-locks for them, But I don't know if they are 3/8 or 7/16th studs. anybody have pictures of the two?
Are they the GM LT4 rockers (silver with little bowties on the tips)? If so, they're 3/8".
EDIT: If you order a set from Jeg's, get the set that is for a 0.550" wide slot. The 0.600" wide ones won't fit the LT4 rockers.
Originally posted by TenaciousZ
they are silver with the bowtie emblem on em. So the end of the stud that the rocker slips on is thinner than the end that screws into the head? best as I can explain it right now
Yes, the end that the rocker goes on is thinner. 3/8" and 7/16" refers to the size of the hole in the rocker arm. Stock rocker studs are 3/8".
whitehooptie
08-10-2015 07:02 AM
