how can you tell if your rear is bent?
how can you tell if your rear axle is bent?
can you bend your rear axle from being heavy on the pedal? mostly a stock car, couple of bolt on's im curious
Originally posted by 96-speed
Bend your rear? Bend an axle maybe?
Sounds like someone has been wathcing too much fast and furious and decided to give tech advice .
What are your symptoms?
Ryan
Ryan
Its not uncommon (especially for aftermarket) springs to be off. If an axle was bent, you'd likely feel some vibrations. You can buy rubber coil spacers to "space out" a coil on the shorter spring.
Ryan
Ryan
Ryan
Ryan
Ok...I think I'm reading you now...
It sounds like you panhard rod isn't centering (laterally) the rearend properly. Is the car lowered at all? It is normal for the car to "shift" to one side when lowered. An adjustable panhard rod will fix this.
If it isn';t lowered, it seems strange that it would off to one side, but an adjustable panhard rod could still fix it - assuming I am following you.
hope this helps,
Ryan
hope this helps,
Ryan
hope this helps,
Ryan
hope this helps,
Ryan
Location: Somewhere between a shotgun barrel, and a blood spatter on the wall.
CAPTAIN OBVIOUS... AND HIS INFAMOUS SIDEKICK, FRMULA... ARE ABOUT TO SPEAK...
captain obvious says think back to the great san francisco earthquake of 1847... now... imagine all of that JUST in the cabin of your car...
this is what it would be like to have a "bent" axle...
captain obvious has spoken
captain obvious has left the forum
captain obvious will be here all week, be sure to tip your waitress
BandDirector Blk98ZM6
02-20-2015 07:42 AM
