How did you remove your cam?
#17
Just keep in mind that the cam journals and bearings will all clear each other at the same time time so try to keep the cam "suspended" or at least let it down very gently as each journal is cleared, don't let it fall as that will be banging hard on the bearings and you don't want them scuffed. If you let it down gently, you'll have to pick it back up to continue pulling the cam out so the only reason to let it down will be to reposition your grip on the cam.
Hope that makes sense.
#18
Makes good sense. Thank you. I think i may get the cam out today which is awesome. Im having some trouble pulling off the timing cover though. I dropped the oil pan about 1/4 of an inch but when i try and remove the timing cover it is pulling the rubber piece of the oil pan gasket with it... am i supposed to lift up on it ? or just pull it free?
#19
Personally I've never had very much luck getting the pan gasket to seal again, its hard enough getting it to seal with a brand new gasket...once any oil is on the surface of the gasket, it won't seal even with rtv. Use UltraBlack rtv it seals the best...if it doesn't seal back, then doing the pan isn't all that bad once you get into it.....remove motor mount bolts, and then loosen the 6 subframe bolts until theres just 3 or so threads holding it, remove the top strut bolts, and then jack the motor up as high as it will go and the pan will slip right off after rotating the motor to get the front counter weight and rod connector up out of the way..
Removing the front hub for the timing cover is more of a daunting task for me
#20
I dont know what magic you guys used to remove your timing covers without ripping the gasket...
I ended up tearing mine.. not on purpose, but it still tore. When i looked at how the gasket was wedge into the timing cover bottom there just seemed no way to get that off without ripping the gasket.
Also, alot of people told me to lower my oil plan, but my pan seemed to hit the power steering lines and/or steering rack before it really got any lower than about 3/4 of an inch.
But hey ... oil pan was leaking anyhow...
#21
#22
#23
Wow thanks for the video! I havent removed the cam yet.. I didnt have the long bolts.. I'll probably do it this weekend. i was too busy cursing my torn oil pan gasket.
#24
He seems to really be banging it around in that video!!...I'd take much more care and go slower than what that video shows thats for sure if you're not planning on removing the entire block and putting in new cam bearings.
#25
You are absolutely right. Way too rough taking it out.
