How difficult to replce rear caliper?
Not bad at all.
Once u get the wheel off you will see what needs to be done.
Probably the hardest thing you will run into will be getting the brake line off and bleeding the brakes.
Not that hard though, get a friend to help with the brake bleeding and you should be good.
I just did this and it isn't bad. Like revtime said the hardest part is bleeding the brakes right. There is a bracket on the caliper that you will need to take off, before you take it in for the core. Autozone didn't include this when I did my rear calipers.
carguyshu
01-22-2017 11:19 AM
carguy0119
04-11-2016 11:11 PM
CGM2010CAMARO
04-07-2015 07:44 PM
