how to disable the aigbag light ?
#16
LMAO @ wolfie Vs Nightrider
u guys crack me up
.. the winner of this struggle is ... "THEWINNER"
u 2 need to learn how to READ .. i gotta take out the WHOLE shbang anyway .. gotta replace my broken dash .. thanx to the deployed airbags
but i think i'll put switches in my BCM to control these lights (or just cut them) this way i dont have to pull the cluster again to put in light bulbs
thewinner: whats the best way to take off the top piece ? mine ISNT cracked from the airbags .. but i dont wanna break it trying !!! so just spill the beans .. how do u take the top piece out ?
thanx
PS. i think the cluster is a LOT easier to pull on a TA than a camaro .. for the TAs u dont need to take out the top piece .. camaros u do i think ...
u guys crack me up
thanx
#19
Originally posted by NiteRider
Ok that's enough, go ahead, butcher your car like a slab of fillet minot!!!
Payam just do it via your cluster, don't listen to wolfie.
#20
pull the knee bolster, 2 bolts 2 screws. disconnect the defrost conenction if you have it. take the radio bezel off. 5 bolts.
if i remember right, the cluster bezel has a screw by the fuse box, tilt stick thing, and one by the radio (not sure about this one)
pull thsoe out, then you will have to get a screw driver and pry the flat piece up and the corner where it meets the cluster bezel and the airbag piece i think thats what it is.
once its up a little from the screw driver, slide your hands under it and pull up gently and the velcro should pop loose at that corner.
then i think there is 2 more funky fastener things that hold it down, place a hand on each side of those and pull up.
then there is 2 screws under there i think 7mm and remove those with a wrench.
make sure to get them tight when you put them back or else they rattle a ton, dont ask me how i know hehe. just push the dash back into place.
to completely remove the flat piece, you will need to take off the apillars.
#21
Originally posted by Bud M
Do listen to "wolfie". It's a 10 minute job. I didn't have to remove the glove box when I did it, btw. Cut that brown wire and put a couple of crimp on connectors on it. That way it can go back together easily if you ever decide to. And what the hell is "fillet minot"?
I'm pretty sure he meant "fillet mignon". It's sort of a steak to name it in one raw word. Hey Canadians, learn your French!
#24
Originally posted by madwolf
What do you mean?
If you're talking about my joke, then that's all it was - a joke. No sarcasm or fun made of anyone. I barely passed French myself.
What do you mean?
squarehead
01-15-2015 07:02 PM
