How do I connect this remote starter
I need to connet this remote starter switch to my car while I'm adjusting my rocker arms and I'm not sure how to do it.......Its a 95 with a M6............
It should have two clips. At the starter clip one on the terminal with the purple wire and the other on the large terminal with the battery cable on it. Make sure your car is out of gear and brake on or wheels blocked when you you use it.
Aaront810
08-29-2020 09:34 PM
jackpawt883
09-10-2015 08:53 PM
