How do you change a throttle cable on a 94Z?
It is a pretty easy job...unless you have a full cage lol.
Get under the driver's side dash and disconnect the cable from the top of the gas pedal. Next, pop off the clip on the firewall that holds the throttle cable in place. Then disconnect the clip on the driver's side of the intake...black bracket. Lastly, disconnect the metal wire cable from the throttle body. Repeat in reverse order to reinstall.
Good Luck
Matt
Good Luck
Matt
07-04-2005 05:00 PM
BAD00T/A
07-21-2002 07:35 PM
