How Hard is LCA Install?!?! 1 to 10?
I'm gonna say 3 just because its tricky getting the axle the right height so that the holes line up.
Cuz once you jack up the car, the axle will be a different distance away and its sometimes a pain to find the right height to get the bolt in. Especially if you have relocation brackets.
Other than that its pretty straight forward, 2 bolts.
Took me 15-20 mins on each side including jacking it up.
It took me a couple hours but thats just because over 2/3 that time was spent trying to get one rusted nut loose on the driver side. I even broke a socket with a breaker bar! Eventually I got it though. Its very straigh forward and if you dont run into the probelms I had you should be able to do the whole job within 1 hour. I suggest soaking the nuts/bolts over night.
Aaron
Aaron
i didnt use any penetrant on my bolts.they had rust on them but nothing that my wrench couldnt handle taking off.i agree the only pain is finding the right height for the holes to line up.it is very straight foward though 2 bolts on each lca.
F'n1996Z28SS
08-23-2023 11:19 PM
87Aerocoupe
03-20-2015 01:23 AM
