how to install bottom timing chain gear and hub?
Re: how to install bottom timing chain gear and hub?
The crank sprocket slides over the crank snout, aligned with the keyway on the crank. You can use a short piece of pipe to drive the sprocket onto the crankshaft.
As for the crank hub, use a Grade 8 threaded rod, some washers, and a bolt to push the hub onto the crank snout.
Originally Posted by 95z28txn
i understand what you mean about the gear but on the crank are you saying kust use a bolt to tighten it without any other tool?
Yes, tighten the threaded rod by hand into the end of the crank. Line up the hub then use the nut to "push" the hub all the way on the crank.
