how to install water pump seal
#16
I was just wondering if there is a seal installer to install the water pump drive shaft seal that is in the timming cover I tried to install one today with no luck it pushed the inner seal to the out side dose gm make a seal installer for this seal or what have you guys been useing to keep from folding the inner seal in
J-39087 Driven Gear Front Seal Protector
#18
Location: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
This is also what I did. I'm not sure what size, or brand of socket it was, but it was a deep well just slightly larger than the shaft. I oiled up the socket, and it worked great. Once it was off the socket, and on the shaft, I just pecked it into place with a small hammer.
