How long does it take YOU to change your spark plugs?
Old 10-10-2004, 02:37 PM
  #46
Hawk's Avatar
Re: How long does it take YOU to change your spark plugs?
1 hour w/ AS&Ms
If i had stock manifolds, I'd sell the car if I had to change plugs
Hawk is offline
Old 10-10-2004, 05:55 PM
  #47
lt1camaroman93's Avatar
sallmon, if you didn't live so far away that wouldn't be a problem.
lt1camaroman93 is offline
Old 10-10-2004, 07:27 PM
  #48
Chris 96 WS6's Avatar
With the FLP's I can do mine in 30 minutes including dropping the starter to get 6 & 8, not including time to pull the alternator. Probably 1 hour total start to finish if I am not in a big hurry.
Chris 96 WS6 is offline
Old 11-04-2004, 08:33 PM
  #49
xfreshjiv12x's Avatar
I just changed mine for the first time and it took me about a day to do it. I have the stock manifolds on it. It helps if you have skinny arms unlike me!! I didnt remove anything, just got lots of scrapes, grease, and cursing. But it should be alot easier for the next time.
xfreshjiv12x is offline
Old 05-22-2005, 12:31 AM
  #50
Hawk350's Avatar
12 minutes for all 8
Hawk350 is offline
Old 05-22-2005, 12:35 AM
  #51
NewbieWar's Avatar
Originally Posted by madwolf
Here we go again....
"Yea, I can change mine in 15 minutes with one hand, smoking a cigar and a double whopper with extra onions in the other hand....hmmm now I might as well drop the engine through the bottom in the next 30 minutes to make things easier..."
I'm sure the times will get lower and lower as you get more replies to this post....
Honestly, it was the first thing I did on a 4thgen. Took me half a day to do wires and plugs the first time. I can probably do it in under 2 hours now....(stock manifolds)... less with the long tubes.
first time 4 hours, but i could do it in probably 45 minutes now that i know all the tricks... now i got headers and i could see em all and get to em all... so its probably 30 minutes
NewbieWar is offline
Old 05-22-2005, 12:38 AM
  #52
Hawk350's Avatar
if you are referring to my post, 12 minutes for all of them....all I use is a offset wrench....it's simple.....having headers helps alot
Hawk350 is offline
Old 05-22-2005, 07:38 AM
  #53
pearlpurple's Avatar
If you use the right tools you should be able to do it in about 2 hours.
Plug socket with the hex, a socket that will fit that hex, short extension short handled (flex head) 3/8 drive ratchet and a lot of patience.
My first go at it when I first got my F Body I did did plugs, and compression in under three hours. In fact it is time now to change my plugs again.
pearlpurple is offline
Old 05-22-2005, 09:08 AM
  #54
Hawk350's Avatar
2 hours to change plugs? Jesus!!! unless you still have exhaust manifolds
Hawk350 is offline
Old 05-22-2005, 09:23 AM
  #55
Texas Moderator (1998-2009)
Shawn 97 Z28 M6's Avatar
Pacesetter LT's ....
Driver's side.. 10minutes
Passenger side... Maybe 30minutes. It's easier to get 6 & 8 if you unbolt the starter from the block.
Shawn 97 Z28 M6 is offline
Old 05-22-2005, 09:56 AM
  #56
arrowcamaro's Avatar
took me about an hour with manifolds the first time....
arrowcamaro is offline
Old 05-22-2005, 10:28 AM
  #57
got_hp?'s Avatar
i have jethot longtubes.
i can change the driver side and first two passenger side plugs in about 30 mins.
the rear two passenger side plugs means i have to jack the car up, get underneath, remove the started. this takes about an hour.
got_hp? is offline
Old 05-22-2005, 10:32 AM
  #58
NewbieWar's Avatar
hrmm i've never had to do this... i did all from above and with a bit of patients...
my second go around on one that i messed up the gap, i was struggling for 4 hours one night... slept on it and put it in 2 minutes the next morning.
Old 05-22-2005, 11:49 AM
  #59
Pandamonkey's Avatar
Took me and a friend about four and a half hours.
Pandamonkey is offline
Old 05-22-2005, 11:58 AM
  #60
Hybrid86Z's Avatar
exactly, that's pretty much how long it takes me
and in those 30 min for the passenger...that's also jacking the car, and putting it on jackstands to get to 6 & 8
Hybrid86Z is offline
94Z28LS1toLT1
02-28-2015 08:33 PM
Dan_the_ManZ28
02-21-2015 02:01 PM
mritter1965
02-09-2015 07:01 PM
Jazsun
12-29-2014 12:14 PM
Quick Reply: How long does it take YOU to change your spark plugs?
