How much life did I take from my engine?
On sunday I decided to flush my radiator... well, everything went normal until monday night when it overheated... it seems some air bubbles are stuck in the engine and it made my engine overheat It reached the top of the temperature gauge for a few mins until it suddenly dropped... Everything seems normal right now... engine is strong... what else can be harmed when overheating?
Re: How much life did I take from my engine?
main bearings and rod bearing...i did the3 same thing...now the motor is in about 300 pieces...complete bottom end rebuild...chck for knock sounds a bit like lifter tappet...
Daniel
Daniel
Daniel
Daniel
if it suddenly dropped i can guarentee that you fried your sending unit...or you happen to get lucky and that was a air bubble that worked its way out at the right time
If everything is running fine, I wouldnt worry about it. One question though, why did you run it hot like that for a few minutes? Again, if its running fine, you might have dodged a bullet but next time as soon as you see it getting hot like that, kill it!
BTW, the car has 64,000 miles
I have done several radiators that always happens. If it jumps up and down the engine isnt that hot the air bubble is. Your engine temp probably didnt rise at all.
Originally Posted by Cnadian_Camaro
I have done several radiators that always happens. If it jumps up and down the engine isnt that hot the air bubble is. You engine temp probably didnt rise at all.
NewsBot
01-21-2015 06:10 PM
