how much power can a stock crankshaft take?
exactly like the title says. i have a 355, but it has the stock crank (reworked of course) im just curious how much power i can put through it before i snap the little guy in half
see i run 11.5 spinning the 1/8th, i have a set of heads, new cam, and a ported intake on the way, plus suspension. i also spray a 300 shot, so im realy hopeing to make 700rwhp on the spray. and it had the arp studs i just didnt know how much it can take.
I've heard 600rwhp. But each crank is different. I wouldn't count on it to last long, but a few hits shouldn't send you packing ... everytime you hit it you will get closer to blowing it. So i'd plan on a rebuild and fix the problem before it becomes a serious problem.
honeslty if anyone can put up more info on this subject id like to know. Im gonna have a fresh 350 w/forged pistons and rods and stock crank.
Gonna run gm847ported heads, and a 125 shot
10-31-2016 11:09 AM
