How much power would I gain n/a and be giving up on the juice? LSA Related
Im thinking about going to a 108 or 110 lsa on my 383 stroker. Its going to mostly be n/a, but sometime in the distant future i plan to add a fair amount of juice 150-200hp shot.
Would a 108lsa be easily tamed into being driven with a dyno tune? I guess the question is, is a 108 necessary over a 110? big difference? cause my neighbor has a camaro on a 106 and that ****er just lopes like a mother.
as far as lsa goes, general rule is tighter lsa will give a peakier powerband higher up? and wider will do the opposite effect?
You mention nothing of the actual cam specifications.
The PS boys are typically in the 102-104 lda range btw.
A 108 lda is not typically seen on multi point fuel injected engines but it is by no means "radical" until duration is increased.
You have a 383? The cam you're interested in, what are it's specs?
Mike
Mike
West South Central Moderator / Special Guest
110 is get my vote.
like Mad said, when it comes down to it.. OVERLAP is what makes it idle rough. so, just tightening the lobe sep wont make "too big".. unless the duration is there. IMO, a 230ish cam on a 110 would be fine. big, but fine.
i went with 111
but as per what Dr. Krause taught me-
work on the Inake/opening/closing as well as the exhuasts open/closing points. LSA should "work itself out" after you pick the correct points.
F'n1996Z28SS
08-23-2023 11:19 PM
